Touring air shocks installed w/pictures
also as P51 said, get a proper pump. i found mine on Ebay and it does 1lb increments which is really what you want for fine tuning.
either way , you are going to love them come spring
How many times did you visit Vancouver? How do you know E. Hastings? Lol where the hockers are lmfao
It's quite warm today, I decided to get a day permit for a test ride. First I tested the shocks without air, I am impressed, ride quality is night and day, noticeable improvement, almost thought I was riding my old Softail fatboy , I don't even feel little bumps I used to on hwy. Hit a feel pot holes and it did not bottom out, the ride is so smooth. Then I went to the gas station and put 10 psi on each shock, don't feel much difference but cornering is much stiffer, I really like it. Girl friend is too chicken s h i t to ride due to cold weather, will take her out when it gets warmer, I bet she's gonna love it. Money well spent on performance and appearance, I love these shocks, highly recommended.
P.S. Putting air in is a bitch, either get a Harley shock pump or an electric air pump, that way you can preset the air pressure. I tried to play with it with a tire pressure gauge and air chuck, sometimes too much, sometimes not enough.
I always ride solo, and believe it or not, I use a max of 15PSI.
Max pressure is 50 PSI, according to the Harley Davidson installation instruction sheets below.
54631-02B
http://www.harley-davidson.com/en_US...ts/-J02179.pdf
54635-09
http://www.harley-davidson.com/en_US...ts/-J04754.pdf
Profile Low Touring Shocks
http://www.harley-davidson.com/gma/g...bmLocale=en_US
__________________
2006 Road King / 1960 Fat Boy
hmm......I wonder if the standard height ones are higher, I couldn't find instructions for those. No matter thought, can't think of a reason to go that high anyways.
54631-02B
54635-09
Using more pressure then bleeding them down with a pressure gauge that has a bleed off valve works well, the trick is not to press the bleed off valve, you have to push it sideways, tilting the bleed off valve, this will slowly release pressure.
__________________
54631-02B
54635-09
__________________
