Ignition Fuse blows every time......
Bike wont start. Turn key on to on position, lights come on, click switch to run and POP, Ignition fuse blows every time. Swapped out Ignition relay as a precaution, still same result.
Recent bar swap, bike was running after this was done.
Going to check the wiring at the switch housing on the ignition side.....any other ideas?
Thanks
John
Thanks
John
Updating an old thread....you guys were right again! The ignition switch wires got pinched between the bars and the switch housing when it was clamped shut. The vibration of the bars cause the wire sheathing to get stripped off and the shorted out when I turned the ignition on, blowing the fuse every time......
Thanks for the help, sometimes I make stuff more difficult than it has to be....over thinking a problem is sometime worse than not knowing what to do.....
John
John
Nova Sportster
Electrical/Lighting/Alarm
05-05-2013 08:24 PM
crawfordcl
09-15-2010 10:52 AM
