Need Pics of Diff Color Exhaust Coatings
Old 12-06-2006, 10:49 AM
chewster77's Avatar
chewster77
chewster77 is offline
Default Need Pics of Diff Color Exhaust Coatings
I'm going to have my exhaust ceramic coated at Performance Coatings and i'm torn between two ideas. In both ideas i won't be using the heat shields.
First idea is to have them coated in the Satin Fresh Blast color and put on as is.
Second idea is to have them coated in the Satin Black finish and wrap all but the last 6"-12" in the white colored heat tape/wrap.
Has anyone done anything like this on a 2006 Street Bob?
If so can you please post pics? Even if you have another bike it would be nice to see what it looks like.
thx
Old 12-06-2006, 11:21 AM
Alaska Bobber's Avatar
Alaska Bobber
Alaska Bobber is offline
Default RE: Need Pics of Diff Color Exhaust Coatings
Not quite the same but close...should get your imagination going.
Old 12-06-2006, 12:11 PM
kpreese's Avatar
kpreese
kpreese is offline
Maybe I'm just a wimp, but I tried running my exhaust with no heat shields and hated it. That extra heat coming from up under the seat was uncomfortable. At long redlights or when I was stuck in some traffic, I thought it was going to melt the vinyl on the seat and maybe even singe my jeans. I'm sure different exhaust designs would affect the header temperature and maybe mine are routed too close to the seat or something, but I would think any exhaust without heat shields is going to throw some heat up under your right leg.
Attached is a picture of my black ceramic coated exhaust with no heat shield and my signature has the chrome heat shields. Your coater *should* be able to coat your existing heat shields and that might be the ideal solution. One more note, the header wrap keeps the exhaust temps HOT. That's a slight performance advantage at the strip and maybe it looks cool, but it can cause premature failure in the exhaust system. I'm not saying don't do it, just saying you should be aware that there is a risk.
Kevin
[IMG]local://upfiles/6482/3D92F4072ED548F986400CBF0223CBC7.jpg[/IMG]
Old 12-06-2006, 02:15 PM
Cav's Avatar
Cav
Cav is offline
ORIGINAL: kpreese
Kevin
Yep, the RB Racing website is VERY emphatic about that issue (with gruesome pictures to make the point)...and their stuff is pretty high quality by any measure. They strongly discourage the use of wrap for the street.
Old 12-06-2006, 03:25 PM
chewster77's Avatar
chewster77
yea i was worried about the heat but my other bike is a ducati and those pipes are directly under the seat so you can imagine the heat that dissipates off them, hopefully the harley won't be any worse.
Old 12-06-2006, 04:22 PM
GeeRam's Avatar
GeeRam
GeeRam is offline
ORIGINAL: chewster77
[sm=hail.gif]
The prefect V-twin pairing you have then.
TZG18FLTRU
03-16-2017 10:53 AM
Keith4001r
04-03-2016 02:35 PM
sbeast
06-23-2014 05:25 PM
mikeo33y
03-16-2013 05:11 PM
brandanfinn
05-16-2007 01:05 PM
Quick Reply: Need Pics of Diff Color Exhaust Coatings
