What is the difference between RSD and Road 6 Customs Apes Hangers
I am really looking to get 12" bars to replace the stock ones. I think it will help my lower back. I figure instead of leaning forward my hands will be in a more natural position and i will sit more upright and not slouch. Anyway, I am looking at these to brands. The RSD are like 300 and the R6C are 140. Both look the same. To all that have the R6C what are your thoughts on the quality. I am leaning towards those because of price. I was thinking of the 12" but the 8 or 10 look good to. Dont want my hands over my shoulders so i think no higher than the 12".
To those that have 12" apes what cables did you replace. ALso how much longer did the wires have to be extended. WIth those that have 8" will I have to replace my cables? My bars right now are on a 5" stock riser. So maybe with the 8" and 1" risers that may help to and I wont have to go and replace my clutch, brake and throttle cables. Not to mention extending the wires.
This is really the only winter project that i would like to tackle. I think all in all this is going to cost 300-450 bucks.
Thanks in advance.
Just by looking at pics the RSC look like they slant down more at the grip ends than the R6C.
These are the RSD Bars
These are the Road 6 Customs bars
Thanks in advance.
I am running wild one outlawz 12 inch apes. I didn't have to change out any cables or increase wiring at all. Stock cables and wiring worked fine. for anything higher however I think cables and wires are a must. I like the road 6 customs. I almost went that way. quite a few people from this forum have them and seem to like them.
So kunpow you went with the 8" bars? I think it looks great. Since i will be pulling the stock 5" risers and putting on 1-2" risers i wonder if they will only be a few inches above the stock bars. Its going to be alot of work. But you said you didnt have to do anything to the cables or wires . I wonder if the 10" bars would be fine. What is the distance accross the bottom of those bars. Road 6 customs has 2 different styles. One for a narrow and wide. I believe the narrow bars are 9.5" on the bottom and the wide are 11.5 accross the bottom. I really like the idea of not having to change out the cables or wires. Do you think the cables and wires will give you 2 more inches so i can go for the 10" bars?
that guy i was thinking of doing the same thing. hit home depot and buy a legnth of 1" pvc and mock it up. very easy to do since these bars are just straight lines.
hd dan your saying you went with 14" bars from Road6Customs. your 5'8" and your hands are below your shoulders. if thats the case i would need the 14" bars. i am 6' tall.
hd dan your saying you went with 14" bars from Road6Customs. your 5'8" and your hands are below your shoulders. if thats the case i would need the 14" bars. i am 6' tall.[/QUOTE]
Pontiac, they are just slightly above shoulder. The bars do slant down quite a bit from the "peak" of the 14" height. They also come with plastic end caps at the riser/grip intersection. I put some 12 gauge brass casings in place of plastic.
I answered your PM.
I'll also say it here, I have the R6C 12" apes with 2" risers. Like you, I felt like I was leaning too far forward and arching my back. It didn't feel comfortable after a while and I wanted a more upright relaxed position.
With the 12's and 2" risers, I sit up better and my hands are below my shoulders and feel a lot better.
As far as cables, I replaced my clutch, idle, and throttle cables with stock+6" so if I wanted to go up to 14's I will have plenty of cable. Also, I replaced my front brake line with stock+6" and I purchased all 4 from Magnum Shields and they are the black pearl series.
Also, I feel I have better control with handling with this current set up over stock and I really like them.
You'll wonder why it took you so long to do it after you ride with them.
