XiED's... thoughts or reviews?
Old 12-11-2011 | 06:29 AM
Foxster's Avatar
Foxster
Originally Posted by Twangmaster
I'm ... planning on going to Stage 1 on my '11 WG
Then Xieds aren't for you.
They aren't a stage-1 solution. What they do is richen things a bit at low revs and throttle openings, this reduces temperatures and may fix some minor surging issues. An OK idea on a stock bike but on a stage-1 bike they do nothing during open loop running (higher revs and wider throttle), which is where you are trying to get a benefit with your stage-1.
What they are not is a performance upgrade to the fueling to match the $x00s you have spent on the pipes and A/C. For that you need something like a PC or SEPST.
Old 12-11-2011 | 07:01 AM
artpe54's Avatar
artpe54
I have a set on my 2010 Super Glide with D&D FatCats and a AN Big Sucker. Bike runs great!
Old 12-11-2011 | 09:58 AM
stilup's Avatar
stilup
I ran them a year with the rush 1.75 slip-ons and K+N filter element only and it was OK, the low end improved . For the money they are a great upgrade.
However if your going with a high flow intake I would recommend a tuner instead.
I had decell popping slowing down in lower gears. I don't now.
I finally moved up to a tuner with the high flow intake. I am looking for a better exaust next.
Old 12-11-2011 | 12:40 PM
Twangmaster's Avatar
Twangmaster
i'm thinking if I can find some used, i'll give them a try, but probably on going with a PCV before too long. Thanks for the great info.
Old 12-11-2011 | 02:43 PM
stilup's Avatar
stilup
I got my set in the garage.
PM me for a sweet deal.
Old 12-13-2011 | 09:19 AM
ynots's Avatar
ynots
Ditto!
Im running xied's (2010SG) with the ness big sucker and bub 7 two into1. No more pinging or decel pop. I dont know if I would waste my money on xied's if I was still running a cat? lean conditions suck
Old 12-13-2011 | 02:33 PM
reclaimer53's Avatar
reclaimer53
I ran them on my 2008 FXDF when I put my short shots on with no a/c upgrade with out any problems.
When I changed my A/C i went to a power commander from Fuelmoto and sold them to someone else that was just doing a pipe change.
Old 12-13-2011 | 09:05 PM
marcortez's Avatar
marcortez
These look almost too good to be true. Great Price. I'm only planning on going to Stage 1 on my '11 WG, and these look like they may do the trick. Not a lot of information on them though, and i'm looking for some comments from owners who have had them installed. Thanks all in advance...
http://sales.nightrider.com/XiED-Fue...ement_c_1.html
I say just do it!!
It will allow your bike to run cooler with the fuel enrichment, and save you hundreds of clams in the process over a tuner.
I bought a brand new SuperGlide and drove it stock from Phoenix AZ to Las Vegas NV and back....in 100+ degree heat.
It was a hot ****** for sure.
Back at the dealer in Phoenix, I purchased a V&H exhaust system and had them install it, along with a SE stage1 air intake and the Xied.
I then drove the moto from Phoneix to Yuma AZ in hot ****** heat again, yet I could distinctly notice less heat coming up from the engine.
No I did not put a gauge on it and am only guessing....but I know hot from ****** hot!!
If your looking for a cooler running engine (which you should be by the way...heat is a killer of all life, flesh and steel) then the Xied is for you.
If your a highly tuned sort and want your engine running like a Swiss watch.....then a more advanced tuner could fit your bill.
$100 clams vs $400 clams....you make the call...but a Xied will work and it works rather well with no noticeable hicups.
Spending a hundred clams on a device that helps your engine run cooler should never be considered a waste.
It is money well spent until such time you decide which road you wish to take.
jisananimal
10-20-2011 01:20 PM
AussieTX
07-23-2011 07:23 AM
bigmick23
Exhaust System Topics
04-05-2011 05:17 PM
bwhte
03-10-2010 05:53 PM
Aardvark
08-28-2008 09:02 AM
