I may have stripped the exhaust stud that bolts the exhaust to the motor. Any suggestions or help on how to fix it would be appreciated.
If all you did was strip it, put some penetrating oil on it and grab some vise grips and unscrew it. The replacement stud is less than a dollar. If you broke it off, you'll probably need to us a drill and ez out to get it out. If you there's a little bit still showing, try cutting a slot iin it and use a screwdriver.
When I changed mine out the last time, one of the nuts was seized on the stud. The stud came out with the nut on it, so I just found a bolt that was the same size, with a washer, and put that in there for now. I plan on fixing it later on, but it has held up fine for the time being. No leaks.
