True track on '12 FXDC? With HD oil cooler?
Any one have any input on this?i read something about pre 09 frames needing the true track. Did they change something from 09 on? I'm also thinking about adding an HD oil cooler. Looks like they changed the design though, to mount on the frame tube. Maybe I'm wrong. Basically I want to know if I should go with the true track while my bike is apart or will I not need it? And if yes will it work with HD's oil cooler?
I'm planning on getting an oil cooler. I was told to look at coolers that have a thermostat that turns the cooler off during cold weather. Whichever brand you get make sure it has a thermostat. Of course it depends on your environment...up north you may not need a cooler.
If you go with the horizontal oil cooler, you may have some issues with the True Track as they use the same mounting holes in the engine if I remember correctly. If the oil cooler is vertical and mounted to the frame, no issues. I have that version.
Sputhe claims can mount a horizontal oil cooler on their version.
If you are referring to the following HD oil cooler,
Premium Oil Cooler Kit for Dyna® Models: see below for description
then whether you choose to mount the True-Track bracket or the Sputhe bracket there is no difference. The front bracket of either model mounts direct to the isolator as does the oil cooler:
The True-Track mounts in front of the oil cooler and provides long enough stainless steel bolts to compensate for an oil cooler install. Minor modification may be necessary.
True-Track
call our tech line if you have any questions at 818-445-6204, we're here to help
This cooler was designed specifically for Harley-Davidson® to out-perform all other coolers in the industry. This cooler features a unique "Turbulator" system that evenly distributes oil across the cooling chambers. The air fins are designed to efficiently dissipate heat. This popular Touring oil cooler has been re-designed to simplify installation and enhance performance. The larger heat exchanger provides additional cooling efficiency. Kit features an adapter plate with integrated thermostat that allows oil lines to connect to the oil filter bracket. The thermostat activates at 185°F (85°C). Kit comes complete with mounting hardware and precut oil lines. Kit includes Chrome Oil Cooler Cover.
Fits '06-later Dyna® models (except FLD, FXDSE/2, FXDFSE/2 and California models). Does not fit with Front Spoiler Kits or Definitive5™ Filtration System Kits. Fits with all H-D® Engine Guards.
MSRP US $299.95
True-Track
MSRP US $299.95
