Street Bob exhaust
I am not aware of any Street Bobs built before 2006, that does not mean there weren't any but none that I am aware of. The older pipes should fit on the bike but there are several issues you will need to overcome. First those years were carburetored and not FI so no bungs for the O2 sensors. Second you will need to make your own brackets or modify the stock ones. If you are using a tuner that does not require the O2 sensors it will be a lot easier as making a bracket is not to difficult. If you require the bungs you will need to drill holes and have the bungs welded in. This is a doable project but it might not be worth the effort.
Thanks guys, What I'm being told is the 2-1 exhaust I have fit the 1991 - 2005 super/wide glide models. I'll have to check and see if it's worth the effort to put them on the Street Bob.
Probably makes more sense to sell these (V&H Competition) and get the right one for my bike.
Thanks for all your input.
