V&H 2012 Pipes
#31
You thread the O2 sensor into the adapters first with anti seize, then you thread them into the pipe and tighten them down. The best way to do it is to disconnect the O2 sensors first (on dynas there is a plug under the seat and one in front of the engine, the one with the back plug goes in the rear pipe) then pull the pipes off with the sensors still in place. If you are getting the black short shots I would highly recommend covering the heat shields in blue masking tape when you install them as they scratch super easy. Here is a pic of the bung adapter I used from Bassani, and also a pic of my bike (because I am super proud of how it turned out). Put Woods TW-777 cams and Bassani Road Rage 2 exhaust and a Roland Sands air cleaner.
#32
#33
Yeah, I would definitely CALL V&H, I called Bassani to get my adapters, they told me the did extensive testing. However, the O2 sensor itself only extends bast the adapter by maybe an 1/8 inch. Bassani assured me it was enough and it seems to work fine. I can't imagine V&H not offering something similar. That being said, I know for fact that short shots will sound good on that bike, however, in my opinion they are over used. I have seen way too many sportys and dynas using the same pipes. If Value is an issue, they are the way to go. I spent extra to try and get away from the normal exhaust and I am EXTREMELY happy with my Bassani Road Rage 2's. However, I did put big cams in mine which makes a big difference.
#35
#36
#37
If another company is offering alternatives, I don't see why they shouldn't either.
#38
Just spoke with V&H over the phone and they were pretty informative. The gentleman told me that they will be releasing staggered short shots around January or February. I asked about the O2 sensor adapters and he said they aren't offering them because the whole reason HD changed the O2 sensor was to get them deeper in the pipe to get a better reading and thus a better tune.
Using the adapters moves the sensors farther out of the pipe and defeats their original purpose. He also said HD changed their ECM module and they would be releasing a brand new fuelpak within the next month.
Sounds to me that they are at least doing things the right way and being thorough about it. Guess I'll just have to wait.....
#39
Well, being that I installed cams and air cleaner and exhaust all in the same shot I can't speak of the performance gain from the pipes alone. However, these pipes sound AMAZING. With the cams and everything the throttle response is UNREAL! I have not remapped yet, I plan on doing a dyno tune as the bike is running really rich right now.
#40
Just figured I would update this thread for anyone with a 2012 Dyna such as myself....V&H have posted the Staggered Short Shots on their site for the 2012 model. I don't know if they are officially released yet because there is no where to actually purchase them. Ill post the link....
http://www.vanceandhines.com/store/d...lsystems/47227
