V&H 2012 Pipes
Old 10-29-2011, 11:38 PM
Grich171's Avatar
Grich171
Grich171 is offline
yeah i emailed them a few days ago...i suppose you could just get an o2 bung adapter to fit the threads and all that n just get the ones that are out now....but as of now for a direct fit they only have the big shots and the big radius for the 12s
Old 10-29-2011, 11:52 PM
BigBlue2012's Avatar
BigBlue2012
BigBlue2012 is offline
Originally Posted by Stag556
The tuners will be different for the 12s too? I was hoping HD didn't change anything in that respect.
Yes, they changed the system for the 2012's. They use a CANBUS system like teh 2011 softails. I have been waiting for 2 months to order a tuner. I personally will be going with the power vision but havent been able to find any type of tuners yet...
Old 10-29-2011, 11:59 PM
spankdog's Avatar
spankdog
spankdog is offline
I keep hearing that but I have a Super Tuner on my 2012 Fat Bob
Old 10-30-2011, 08:45 AM
Stag556's Avatar
Stag556
Stag556 is offline
Correct me if I'm wrong, but can I just install the pipes and have the dealer do the download to the ECM? I don't plan on doing too much motor work, so I wouldn't really a tuner right? Just the one download and I should be set?
Old 10-30-2011, 09:17 AM
dirtdobber's Avatar
dirtdobber
dirtdobber is offline
changing the bun isn't that hard. Any exhaust company can do it.
Then you could use what ever
Old 10-30-2011, 10:56 AM
Fiasco00's Avatar
Fiasco00
Fiasco00 is offline
Stag, if you are only running pipes and an A/C you can get the SE stage 1 download from your dealer, however, these are canned downloads designed for the SE stage 1 kit, so if you are running other pipes and A/C the download will not take full advantage.
The 2012 Dynas now use a 12mm O2 sensor as opposed the the older 18mm, softails and the bigger touring bikes have been using the 12mm sensors for about 2 years. Like I said before, Bassani is just shipping their pipes with bung adapters, makes sense to me as they don't have to carry a separate part number for pre 2011 bikes and 2012 bike.
Old 10-30-2011, 12:15 PM
Stag556's Avatar
Stag556
Stag556 is offline
Thanks a lot fiasco, gave me plenty of insight into this. I just plan on running pipes and an air cleaner. The dealer download will most likely be sufficient for me and in the future, if I decide to have motor work done, I'll invest in a tuner. Thanks again.
I would assume the dealer download will still utilize the O2 sensors? Ill have to email V&H to see if they can make the adapters like Bassani.
Old 10-30-2011, 12:33 PM
hellbob37's Avatar
hellbob37
hellbob37 is offline
Okay, so in theory the big shot exhaust that is technically for an 06-11 dyna will work on my 12 superglide with the use of these
http://www.suburbanharley.com/eshopp...SENSOR_BUN.htm.
Old 10-30-2011, 04:15 PM
Fiasco00's Avatar
Fiasco00
Fiasco00 is offline
Yep, looks like the same adapters I put in mine.
Old 10-30-2011, 04:16 PM
hellbob37's Avatar
hellbob37
Does the o2 thread into them and then they thread into the exhaust or are they weld ins? I'm about to just wait for the right exhaust. Lol. F this.
Quick Reply: V&H 2012 Pipes
