What solid wheels fit my wide glide in the rear?
Love the look of matching spokes but I have found a deal on a solid style rear wheel from a '91 softail that I can't pass up to try a diff look on the bike. What do I need to find year wise and bike wise to get a solid rear wheel to fit with no issues on my '95 wide glide? Both wheels are 16x3 and I read if under a 1999 they all will swap over with no mods or spacer changes.
It's not so much the width of the wheel that matters, it's how wide is your rear fender?You have to look at the space you have around your brake caliper.How wide of a tire do you plan to run?How much space do you have between your belt and your tire?If you just want the 16x3 the only thing you have to look at is the bearings!Sportster and dyna will fit right on up to 05.I run a 17x4.5 from a softail Deuce(It bolted right on)
dirtygurty
Wheels/Tires
07-04-2015 08:24 AM
pur pony
Wheels/Tires
03-02-2015 08:03 AM
