Anyone know/run this oil cooler?
Wimmer...
http://www.wimmermachine.com/_html/22.html
8inch tube is just $105, adapter for Twinkie motor is $115...
So $220 for the set up and it looks like it'll be pretty low profile on the down tube.
Im no Harley mechanic but I really cant see how an oil cooler could make it run hotter unless there was a blockage or it was installed completely wrong. Just that fact that the oil is coming out of the engine through a rubber hose and then back would offer some degree of cooling effect. I could see it not cooling enough to change the temp, but hotter? Maybe there wasnt enough oil to make up for the added capacity of the cooler?
I have been told that same thing all my life. If you run a chrome oil cooler, it wont cool anything. My only experience was running a chrome oil pan on my old muscle car. I was told to replace the chrome one with the stock pan to see if it helps with heat. Sure enough temp dropped 10 degrees by just replacing the chrome pan.
