Frame Rust 2012 Wide Glide
While riding 2 up last weekend, we scraped a speed bump. I was putting some touch up paint on it when I got home and I noticed rust coming from the rear side of the bracket the side stand is attached to. My old softail didn't have this piece, I'm guessing they are due to the low frame height on the wide glide to prevent frame damage. Anyway, the front of the piece is welded and the back is open. There are two pins in the side which seem to be where the rust is coming from. These pieces are on bost sides of the frame. Does anyone else with a wide glide or other dyna with this part have rust coming from inside it?
i did the exact same thing to day with my dyna street bob 6 months old!
scraped my right side, and when checking it i found traces of rust on the welded part on the the frame that the mid mounted fot pegs i mounted on! and as you descibe its only welded on the sides and in the front and rust comes on both sides of the frame! i´m thinking bad paint jobb and warranty issue? a new bike should not rust! I didn´t buy it to ride to church on sunday!
I´m riding almost every day hole summer and some times it´s rainy! :O(
note: I haven´t had the time yet to contact my dealer, but anyway it sucks!
Its just the beginning. Fairly poor finish on Harleys these days. Lots of folks from our club here in the UK have had everything from minor paint bubbles through to whole tins with paint flaking off.
On my '10 Fat Bob the paint bubbled up and peeled off inside the rear fender, same on the front fender but on the top surface around the mounts, nearly all the bolt heads corroded and were replaced, on the tank and rear fender surfaces the paint is so thin it wipes away with a cloth leaving streaks of primer coming through, on the frame under the seat the paint all flaked off and the surfaces went rusty...and several other small bits.
![Big Grin](https://www.hdforums.com/forum/images/smilies/biggrin.gif)
Oh no...I can tell you that we have the same **** here in Germany.
All new (since 2007) Twincams in our chapter are rusty because the paint is totaly worse.
Also big problems with electric and the engines are running to hot (damaged lifters and gaskets a lot).
The company straight walk to the old AMF ****!!!
the lacquer on top and bottom yokes have gone white too, but as im planning to powder coat them, its not a big issue for me.
Can't believe this thread came back to life just before halloween a year later..... Zombie Thread!!! Anyway, i've sice had flaking under the seat and a few other small spots. For my own sanity, i just got a little rust remover and touch up paint. Now i just clean, touch up and ride. Won't stay new forever and i truly love my bike now that i don't worry about every little thing. For those with big blue flame, be sure to never let anything chip the actual flames, as the MoCo does not make a touch up paint for that color! I found a close match at a local paint shop and used that on a rather large chip sustained behind a semi on the way back from Sturgis last month.
welder
09-15-2009 12:25 AM
