Motor mount bad or good 10/11 Wide Glide owners
Old 10-10-2011, 03:10 PM
pontiac69's Avatar
pontiac69
pontiac69 is offline
Default Motor mount bad or good 10/11 Wide Glide owners
I thought i read some posts about dropped front motor mounts. 2010/2011 wide glide owners look at your front motor mount. Does it look like this. I thought there should be a gap between the rubber and the top plate. I have only 2500 miles on it.
Attached Thumbnails Motor mount bad or good 10/11 Wide Glide owners-100_0587.jpg   Motor mount bad or good 10/11 Wide Glide owners-100_0585.jpg
Old 10-10-2011, 03:25 PM
JaronB's Avatar
JaronB
JaronB is offline
Yea that shouldn't be touching, especially that much. If you are getting extra vibes, there's a good chance that is your source. Here's the thread from my old vs new mount. You can tell the height difference. It was such a nice difference when I put the new one. I ended up putting the shims back in because it will help with stretching the rubbing out and making last a little longer hopefully.
https://www.hdforums.com/forum/dyna-...ms-smooth.html
Here's the shim thread.
https://www.hdforums.com/forum/dyna-...today-wow.html
Some have took the mount off and cut some of the rubber off, but it's only $100 for a new mount.
Old 10-10-2011, 03:30 PM
JaronB's Avatar
JaronB
JaronB is offline
I just went out and looked at mine and I have about a 1/16 gap, but no touching.
Old 10-10-2011, 04:44 PM
South Jersey Scooter Trash's Avatar
South Jersey Scooter Trash is offline
Hey Pontiac just for the hell of did you contact the dealer and if you did what did they say just curious.
Old 10-10-2011, 08:19 PM
pontiac69's Avatar
pontiac69
Thanks Jaron
Nj, I havent seen a dealer about it yet. I just noticed it today. I figured i would see what the forum has to say before seeing the stealership. I like to go in knowing more than them.
Old 10-11-2011, 04:13 AM
pheur's Avatar
pheur
pheur is offline
Hi,
Mine looks exactly like that, an -11 sold in Sweden. I have actually talked to the service guys about it, they just shoved me away and told me that they all look like that (they took a look at their other scoots on the floor I guess). Didn't matter that I refered to the service manual and that it says it should be a gap.
Old 10-11-2011, 06:56 AM
Tnbrit's Avatar
Tnbrit
Tnbrit is offline
Thanks Jaron
I don't like to generalise,but if the service desk at your dealer is anything like my dealer,just being awake should be enough.
On a more serious note the Service Manager at my dealer seemed to take a really dim view of FORUM knowledge,& it really got his back up when i said i had read stuff on the forum,i suffered with vibrations on my last Dyna & it was never cured,i tried asking about the rubber on the mount touching the mount as you describe,his solution was to look at a couple of Dynas in the showroom & say the rubber was touching on those also.so it must be ok.
I'm not saying you'll run into the same attitude,but I might try a different tack about where I gained the knowledge.
Best of Luck & hope they sort it for you.
Old 10-11-2011, 07:50 AM
pontiac69's Avatar
pontiac69
I hear you on mentioning "i hear from people on a forum" tactic. Wouldnt be my approach. As i said i like to know from fellow members how there front motor mount looks. If most that answer here say theres touches then i wont worry bout it. If they say that shouldnt be that way and that the service manual says there should be a gap, then I go into the dealer with personal knowledge that there is something wrong. I know it wasent like this when got it.
Old 10-11-2011, 10:33 AM
O.F.'s Avatar
O.F.
O.F. is offline
10,000 miles on mine and the upper casting is starting to crease the rubber.
Old 10-11-2011, 11:44 AM
pontiac69's Avatar
pontiac69
So just got back from the dealer and he didnt even need to look at it. He said this happens all the time and to just bring it in and they would replace it under warranty. He said it will probaly do it again one the new one settles. He said they also take it off and shave it down so that it has the proper clearance. He said if i go that direction i wont have to worry about it settling any more. I told him that i would come back later today when my wife gets out of work so she can pick me up.
Quick Reply: Motor mount bad or good 10/11 Wide Glide owners
