lacing a 21 on your stock street bob hub looks funny to me, it raises the front of the bike. the best thing you can do is buy the wide glide trees and 1" axle. your bike will sit correctly and ride right. trees and axle cost me right under 200 bucks. it was a fairly simple swap as well. heres the link for the part numbers i used
If you think going to a 21 raises the front end enough to bother you, just slide the fork tubes up in the triple trees to lower it back down. As it has been stated in many threads, you can still run the stock SB fender with a 120/70/21 tire, which means the difference in radius is not really all that much.
HD was nice enough to make most of the lowers just different enough. Don't know the difference between the WG and St Bob, but know the Fat Bob is set up for dual disc and the fender mounting holes are different.
The right-hand slider is the same between the SB and WG (and in fact is the same part #) but the WG (and FB) left-hand slider are dimensionally different than the SB, having the caliper mounting bosses set about 3-4mm *inboard* as compared to the SB LH slider.
So you will need to either install the WG LH slider, or keep the SB sliders and mount the caliper using a few stainless steel washers to space the caliper inboard so it aligns with the rotor.
