View Poll Results: Want them, hate them or don't care either way!
I want them!
11
19.30%
I wouldn't want them!
30
52.63%
Neutral about them!
16
28.07%
Voters: 57. You may not vote on this poll
How I think a set of Dyna True Duals should look!
Old 09-26-2011, 01:50 PM
Just Blaze's Avatar
Just Blaze
Just Blaze is offline
blueangel hit the nail on the head for me....I'm going for sorta an old gasser or lowrider look....slammed in the rear, high in the front, mine will be slammed (already did that and I have a 23 inch seat height) with 20 inch apes...I just want a set of duals to complete the look...
  #32
Old 09-26-2011, 02:50 PM
JRK5892's Avatar
JRK5892
JRK5892 is offline
there is no room to run it like that, flat out... your other option is to remove the battery and fuse box run it over and down, then relocate the rest of the crap
  #33
Old 02-07-2014, 05:34 PM
Sikdvlz's Avatar
Sikdvlz
Sikdvlz is offline
Is the mount the only problem? Could this set up work if a mount was possiable I mean as far as performance
Originally Posted by Samson_tech
Hi blueangel73,
You have come up with a great rendition of a crossover set of pipes for the Dyna Models. Samson has considered making the true dual crossovers for the Dyna models but we are having an issue with the left side muffler mounting that will not fail under severe riding conditions. We will keep you all posted when we do come up with a proper left side muffler mount.
Thank you,
JR
  #34
Old 02-08-2014, 05:47 AM
AFMM3's Avatar
AFMM3
AFMM3 is offline
Default Duals have been solved
Forgot about this thread, this was solved and I have put about 15k miles on it with no issues.
If you look closely, you can see where the 2009 FLHT exhaust has been stretched 3 inches in the collector.
Exits on the left side while still being higher than the transmission bash plate
Created this bracket to support the mufflers. No connection to fender or saddlebags
The first picture shows an aluminum cross-pipe between the mufflers but behind the tire. This was added when installing the fishtails and created a "Box" around the rear tire that stiffened everything up into one complete unit connected to the motor only.
  #35
Old 02-08-2014, 08:00 AM
butch patrick's Avatar
butch patrick
butch patrick is offline
Originally Posted by twofish
There must be a reason why some exhaust manufacture hasn’t made them yet?
Anyone know why?
Maybe because they would not sell.
  #36
Old 02-08-2014, 08:55 AM
wellsna3's Avatar
wellsna3
wellsna3 is offline
Nice looking bike would have never guessed it was an 08 !
  #37
Old 02-08-2014, 09:43 AM
AFMM3's Avatar
AFMM3
AFMM3 is offline
Even though I put a lot of work into the exhaust, it really only works if you are going for a retro look, like a 1958-84 FLH clone. Dynas are great bikes for building into that look and they really drive nice with 16 inch wheels.
CrazyHog
11-11-2013 09:51 PM
monkeysman03
08-21-2013 07:04 PM
FLHX007
Touring Parts
04-23-2012 08:16 PM
LarryLives
11-14-2011 02:57 PM
Bruce00
03-10-2006 11:46 PM
Quick Reply: How I think a set of Dyna True Duals should look!
