Fender tail light help
this might sound a little crazy,here goes I have a 2011 street bob with the sparto light imo i do not like so what i wanna do is put a 2008 Street bob fender and run a kury panaca light , My question is is the wiring the same on a 08 as 2011 and will the fender fit .like this here the thread i got the pic from
https://www.hdforums.com/forum/dyna-...-pictures.html
If you get an answer you like I have a sparto sitting in my garage. You should have the same connector coming from your STT module. If you do then I can send the connector with pins already attached (I just removed from connector on STT side) and then plug and play. Let me know, post a pic of your connector coming from the sigs or look at a service manual.
it will work. i am putting an '08 fender on my '10 street bob, with a custom dynamics tail light with integrated turn signals. everything is plug and play. you will also need to make sure you get the tail light mounting bracket that's why i got a fender off ebay with the wires and old light already there.
foolioGrimz
09-07-2015 04:02 AM
