Need fuel pump help
Need fuel pump help
I pulled my pump because I suspected that there was a pin hole leak in one of my fuel lines. I was right there was a pin hole in the line between the filter and the pump, but the MoCo does not sell the line between the fuel filter and the pump separately. Have any of you found a work around for this. I don't want to spend $160 on a pump just because this fuel line is bad.
Yep, 5/16 ID I believe and a few worm gear clamps. And be careful removing the old plastic line. Things get brittle in there and the pump nipple can crack.
