Roland Sands Wheels....Are these legit?
Your new dyna wideglide has a stock 21" front and 17" rear whereas the wheels in the ad are for a 19" front and 16" rear. The wheels look legit but those wheels fit around a 2000-2006 dyna but not your year dyna. The rear wheel got much larger on the newer wideglides compared to the older ones.
Legit
+1
I ordered my Performance Machine Wrath wheels and tires through them. They also post deals in the Vendor section of this forum. Do your research on what will fit your bike, decide what you want, then give them a call. Jeff made me a really good deal.
You should also contact Eastern Performance and Hogpro if you want to shop around.
Good luck.
Good luck.
Yes we are a forum sponsor and legit (thanks Drew & jp).
We do have a clearance section on our ebay store and try to make sure the sizes are clearly stated. Typically these are overstock wheels and apply to sizes listed unless there is a scratch/dent set which we will always make note of and list it accordingly.
The Dyna's that come with a 17" rear go with an 18 x 5.50 rear with a 180mm tire when changing to aftermarket wheels. This is a direct bolt on with no mods needed.
Feel free to send a pm or give me a call if I can help in any way.
Thank you
Thank you
