11 WG tail light/turn signal failure
anybody else having continuos failure of their running lights/break/turn signals?
2 weeks in, 1 of my running lights went out, and then the other, i had no rear lights at all...blinkers still worked, but i had to have someone follow me home.
month later, blinker stops working on one side.
now, both running lights are out AGAIN, but this time, i have the LED tail for chopped fender...and it actually worked out cool IMO, cause on the 9/11 Rattle the runway ride to DC, my left side was out, tonight, i notice that the right side is out...looks alright. thoughts? electrical issue, or crappy lights? i may end up switching to all LED...but i don't want it to look crappy.
the bulbs just be failing. i am going to take it back to the dealer, have them put new ones in when one of them stops blinking. not sure if maybe hitting a pothole is causing the filament to shake and break, or maybe something different. this will be the second time at the dealer, the 3rd time they broke. i replaced them the 2nd time because i didnt feel like waiting for them to fix em.
I had one rear bulb go out 3 months ago, took it to the dealer and they replaced it. Last month the other rear went out, same thing except that one blew again a day later. They ended up replacing the socket on that side due to a loose wire.
also my dealer said they arent under warranty so i went and bought a pair
of sylvania LL and stuck them in.
