9 inch MX-Tbars and some new powder
Here are pics of the most recent mods. I ordered up some MX-Tbars but had westcoast make them custom for me, with a 7" riser instead of 8" so they are 9 inch overall instead of 10 and they fit me PERFECT, so comfortable. Handling is not quite as good as the Street Slammers but still good, so it was a good tradeoff. I think they look good, a flyscreen fairing might make it look a bit more balanced though.
Also had the following powdered:
Had my heat shields re-coated in high temp because of all the scratches that were on them from a shop that botched the install. The powder is not a perfect match for the muffler, but I like the contrast.
Fork lowers
brake pedal
Foot peg mounts
highway pegs (mount plate was already black but the piece between that and the peg)
passenger peg mounts
hand levers
shift lever
Next small mods will be a new air cleaner cover to get rid of the football, and maybe one of those HD flyscreen fairings.
This winter I am either going 97" or 107" I am going to talk to my builder and do a cost analysis to see if boring the cases is worth it. I still want it to be pretty reliable. I will probably also have him powder the upper and lower trees and install gaiters while it is at his shop.
Fork lowers
brake pedal
Foot peg mounts
hand levers
shift lever
Thanks. My advice is to get some PVC and mock some up, you can mock up regular T bars to get the feel, don't have to be MX bars. That is how I know I needed 9" and not 10". They will make whatever for you, my 9" were the same cost as the 10", I just had to wait 2 weeks for them to be made
BTW, I don't know if anybody remembers the nightmare I had wiring my Street Slammers last winter, but I made it much easier on myself this time.
I bought a 48" wiring harness with switches already attached from Custom Chrome, pulled this through while sitting on my couch so all wiring was done before they were even mounted. Used some twine and a vac to suck it through, and a little gorilla tape on the harness to tape the twine to it. Took time and did a push-pull and got the wiring done in about 45min, did not need any baby powder or lube to get them through.
bars look awesome! for me, it is a bit to much black contrasts going on, with wrinkle, flat, gloss, satin black all used but then again could be the pics that is throwing it off as well... really dig the bars! time to coat those rotors or go floating when you bust into that motor!
As far as the contrast, I think the pics make it more intense, just cell phone pics. The muffler and shields are not that different, but in the pics it looks drastic.
