How do you like your DWG windshield?
Old 09-06-2011, 02:13 PM
Guest
Guest
Posts: n/a
Default How do you like your DWG windshield?
Beautiful weather this past weekend here in Kansas City...however a bit windy so I headed on down to the ol' HD store to get a windshield.
Got the 18 inch quick-release.
The good:
-That new quick disconnect dealio is the real deal...much better then the older style the used to have
-Took literally less then 10 minutes from opening the box to having it on the bike
The bad:
-I can't say it made much of a difference AT ALL!!!!
What have you found?
Anything that works better...?
I'm thinking that because there is so much rake in the DWG, windshields are tough...
Old 09-06-2011, 03:11 PM
MacBean's Avatar
MacBean
MacBean is offline
i have one that i only use on long trips. it works great to keep the wind from hitting me square in the chest and my arms dont get as tired.
Old 09-06-2011, 03:50 PM
O.F.'s Avatar
O.F.
O.F. is offline
I have one and it helps protect from getting road crap, bugs, etc. in the face but the wind factor is the same, just from a different direction IMO. I get wind from under the tank that comes up and hits me in the throat...you get used to it. I use it sometimes for highway/distance riding and colder weather.
Old 09-06-2011, 06:03 PM
Guest
Guest
Posts: n/a
O.F., looks like you are experiencing the same thing I am...
Do you (and others) think it's because the actual shield is so far forward of us, the rider? I had an Ultra before this and obviously that's a completely different set up.
Does anyone else have the same issues? I think the wind actually starts to buffer right at where we sit because again, it sits so far forward.
Is there a better windshield out there?
Old 09-06-2011, 06:54 PM
O.F.'s Avatar
O.F.
O.F. is offline
Ride with it for a while. Take it off for a while. I think you will find yourself riding with it more often than not, particularly as the colder weather comes on. It actually does make a difference IMO.
Edit - and to your question about alternatives, I don't believe there are any better. I would agree the front end rake makes some difference but a real cure would be lower fairings of some kind. As the parts guy insinuated when I asked, shoulda bought a bagger...
Old 09-06-2011, 07:02 PM
MrMax's Avatar
MrMax
MrMax is offline
I dont have the HD one myself. I put the National Cycle Switchblade on mine a few years ago. On and off in a couple of seconds and makes a big difference in wind/rain coverage for me.
Old 09-06-2011, 07:30 PM
TUCCI's Avatar
TUCCI
TUCCI is offline
The good:
The bad:
Yeah I had the same problem with my 98 DWG and I spent some bucks on the windshield I had, its the rake and ergo of the bike. Had to use a helmet (wasn't keen on those back then...I know dumbshit) but a 3/4 with a drop down shield helped a lot. At times the windshield would work agains the turbulence of the wind to the extent I just rode with the 3/4 helmet by itself which surprisingly was much better? The Wide Glide looks better without a windshield so the helmet had a two fold benefit but you'll need to make your own discoveries.....let us know how it turns out.
Old 09-06-2011, 07:34 PM
EP50's Avatar
EP50
EP50 is offline
I don't have one
Old 09-06-2011, 08:03 PM
p51bombay's Avatar
p51bombay
p51bombay is offline
You can get a replacement with a recurve top from Clear View Shields which may push the wind up and over you.
Old 09-07-2011, 12:33 AM
ynots's Avatar
ynots
ynots is offline
have you tried adjusting it? on my sg i found that mounting it about 1-1/4" from the lower tree works best. If I mount it all the way down on the tubes the wind wants to rip my helmet off
Quick Reply: How do you like your DWG windshield?
