Red Line shockproof and Oil Changing
So, I'm changing the oils this weekend and have been searching the forums trying to decide what to use.
I think I decided to use the Lucas oil synthetic (brother uses it in his sporty) 20w50 for engine and primary, but saw that some people like the Red Line shockproof in the transmission.
My question is, what Red Line shockproof are they using? On the Red Line website there is:
Superlight ShockProof
Lightweight ShockProof
Heavy ShockProof
V-Twin Transmission Oil with ShockProof
Which one are people using?
Also, I'm not near my user manual and wanted to get the oil on the way home.
How many quarts of engine oil?
How many quarts of primary oil?
How many quarts of transmission oil?
Heavy ShockProof
Someone can confirm this (I'm still waiting on my service manual to arrive) for sure.
The gasket is something that you can clean and re-use, but personally I always replace gaskets like that. I'd rather pay the $10 for the gasket than have a leak later on and end up paying for the gasket, and new fluid.
Technically I guess you could just drain it, and fill via the smaller primary fill cover opening (above and to the front of the derby cover), but pulling the derby cover will allow you to see when the fluid is at the correct level.
While you are there, check the tension on the primary chain. I'm sure someone here can tell you what the deflection spec is, its probably something like 1/4 - 3/8" (For a sportster, probably more if you have a bigger model), but get a service manual, or confirmation of the spec before you try to adjust it.
