anyone know how to get left grip off
Old 11-17-2006, 02:42 AM
hellbilly's Avatar
hellbilly
hellbilly is offline
Stage I
Default anyone know how to get left grip off
i want to know if theres anyway to get my iso grip off and use it on my new set of bars or do i have to buy a new pair
Old 11-17-2006, 02:51 AM
Z's Avatar
Z
Z is offline
Default RE: anyone know how to get left grip off
I recently installed a new set of grips and the instructions that came with them said to cut the old grip off with a knife. In my case, I was able to just twist it off. I would think perhaps a hair blowdryer would help. Don't know though. good luck.
Z
Old 11-17-2006, 03:05 AM
Rhubarb's Avatar
Rhubarb
Rhubarb is offline
Stock grips are about $10 for the pair.
Old 11-17-2006, 03:40 AM
Babe's Avatar
Babe
Babe is offline
Just slice it along its length with a sharp knife, peel it off, and clean the old adhesive off with white spirit before fitting the new grip.
Old 11-17-2006, 08:11 AM
06dynablack's Avatar
06dynablack
06dynablack is offline
cut it off its not werth saving.buy a decent pair of grips.the stock ones after so many miles will leave your hands black
Old 11-17-2006, 10:22 AM
AkiSika's Avatar
AkiSika
AkiSika is offline
I took my grips of with compressed air, when I changed my handle bars. Just blow air under the grip and it will slide of easily.
Old 11-17-2006, 10:42 AM
KeithB's Avatar
KeithB
KeithB is offline
Big Kahuna HDF Member
there is a cemical you can buy, but as stated if it's a stock grip just cut it off.
Old 11-17-2006, 11:13 AM
risdo's Avatar
risdo
risdo is offline
Soooo... how do you get the right grip off?
I'm about to change my bars, too.
Old 11-17-2006, 11:27 AM
Azrael's Avatar
Azrael
Azrael is offline
remove the switch housings, loosen the throttle jam nuts and release pressure on the lines, remove the lines from the right grip (watch those little ferrules), the grip should just slide off....
Old 11-17-2006, 12:14 PM
HOGRIDA_06's Avatar
HOGRIDA_06
HOGRIDA_06 is offline
My buddy changed his bars a few months ago and has Iso grips. Pretty much just twist and pull until it gives.
Quick Reply: anyone know how to get left grip off
