anyone know how to get left grip off
Old 11-17-2006, 01:08 PM
risdo's Avatar
risdo
risdo is offline
Default RE: anyone know how to get left grip off
ORIGINAL: ChrisWillis
Soooo... how do you get the right grip off?
remove the switch housings, loosen the throttle jam nuts and release pressure on the lines, remove the lines from the right grip (watch those little ferrules), the grip should just slide off....
OK, so the throttle is not a friction fit like the left grip. Makes sense.
Old 11-17-2006, 05:00 PM
billnourse's Avatar
billnourse
billnourse is offline
I have a hacksaw blade that I ground the teeth off of that will slip between the grip and the bar. Get it started and spray in a little WD40 as you go. Once you get it started, it should come right off. Wash and dry the grip real good, use some grip glue and put it on the new bars.
Right side requires taking the housing apart and taking the throttle cables out of the grip.
Regards,
Bill
Old 11-17-2006, 05:30 PM
steelcowboy's Avatar
steelcowboy
steelcowboy is offline
Yeah I'm like the other guys here they aren't reqally worth saving you might be out a case of beer in cost to replace them. I just used brute strenght and twisted on mine and the glue broke off.
Old 11-17-2006, 09:05 PM
DougsDyna's Avatar
DougsDyna
DougsDyna is offline
Yeh, watch those ferrules $2.89 a piece...... Why do they just disapear when they fall??
Stock Harley left grip comes right off after you remove the clamps (a little twisting motion).
Right grip does the same after the clamps are removed, and cables detached (grip falls off).
Check out the manual.
DougJ
Old 11-18-2006, 04:54 AM
WdGldDave's Avatar
WdGldDave
WdGldDave is offline
Do a search. Somewhere there is a post about using a portion of a wire coat hangar. You just slide it under the grip and then twist it around until all of the glue has broken loose then twist.
Old 11-19-2006, 10:38 PM
Sam's Avatar
Sam
Sam is offline
Like others have said, use compressed air, stop at your dealer, they'll do it for nothing, it takes 2 seconds. As for reusing the grips, you can buy a new set of stock grips for $25 (also, your dealer probably has a box of old used grips lying around that they would love to get rid of), so I wouldn't panic if they get wrecked.
Old 11-20-2006, 02:52 AM
cajunman831's Avatar
cajunman831
cajunman831 is offline
i changed on my dyna.easy to do.sut them off and change,undo all screw s and whatever on one side at a time.make sure you use a large bath towel or something,so
you don,t lose the ferrels.i learned from this forum how to change mines.
Old 11-20-2006, 03:25 PM
WildBill76's Avatar
WildBill76
WildBill76 is offline
I just loosened the clamp and it came right off. There was no adhesive on mine. Saved my old grips. Installed the new ones. Still no adhesive. The clamp holds them securely. I am glad they clamp. My Kawasaki's grips just slid on, and even with adhesive they would break loose.
Harryinny
07-07-2012 06:46 PM
jmorris42
02-21-2011 10:40 AM
2007fxdc
12-10-2009 09:01 PM
RTBrandy
08-07-2009 12:33 PM
Numbawon
07-07-2006 06:28 PM
Quick Reply: anyone know how to get left grip off
