FLD Floor Boards
Hello AFMM3,
My guy at HD parts says " Some of the parts may be on back-order, but he should be recieving some of them next week". Looking forward to it, We looked at the '12 Dyna parts book together the day it arrived at his shop. So, they,re out there. Here's some numbers and $$$ for ya. Keep in mind these $$ may not be full retail. My parts guy treats me pritty good. Ya know what I mean?
# 54174-12....Bracket...68.75
# 54173-12....Bracket...52.72
# 54172-12....Bracket...68.75
# 54172-12....Bracket...52.72
# 50621-06....Board....128.00 (for 2)
# Unk............Brake Rod.70.00 (Approx.)
Hope this helps you out....Best wishes...Tim
J
First i had the HARLEY ones ( POLICE ) which are way over priced and they sit to high up sold them after 3 weeks , i have on the ones on i'm talking about just a different style floorboard but same company , they bolt to your hardware that your mid pegs use you don't need forwards with these they are very comfortable , these move back and forth and pivot up and down , right now mine are set in the middle so i can go forward if i wanted too , i have on a Thunderheader exhaust and they don't interfare at all ,
nevative
the dyna defender heel toe shifter does not fit the new dyna switchback. it hits the boards and the shaft isn't long enought to get the bolt in.
using switchback boards and mounts will lead into exhaust clearance issues on the right side.
a one piece fl heel toe shifter will not work it hits the boards.
there was a dyna cop bike called the defender. it came with boards and a one piece heel toe shifter part number 33706-01
I ordered it we will see if it worx.
George
OK, here I go,
I't's taken about a month to get in all the parts but, I think the wait was well worth it. These are for the '12 FLD footboards and, the people I hang with say " They look like they've belonged there the time."
Here 's a list of P.N.'s and prices as they applied to me, having an'06 Superglide W/Fwd controls and Vance & Hines Bigshot exhaust.
For the footboards:
54165-12 SUPPORT, right footboard $ 52.72
54172-12 SUPPORT ASSY, right footboard $ 68.75
54173-12 SUPPORT, left footboard $ 52.72
54174-12 SUPPORT ASSY, left footboard $ 68.75
50621-06 FOOTBOARD ASSY w/pads $ UNK (See note #3)
50614-06 PAD, footrest $ UNK (See note #3)
7354 LOCKNUT (4) $ UNK
50674-05 BOLT, shoulder $ UNK
4512A SCREW $ UNK
For the brake:
38157-12 BRAKELEVER ASSY $ 111.00
42416-06 PAD, brake pedal $ 4.25
4997 SCREW $ 4.00
38160-12 CAP, brakelever $ 10.95
38161-12 PUSH ROD $ 72.56
42665-03 PIVOT SHAFT $ UNK. (See note #1)
For the shifter:
33789-12 SHIFT LEVER $ UNK. (See note #2)
34887-06 SHIFT ROD $ UNK. (See note #2)
6702 WASHER $ UNK (See note #2)
7736 ACORN NUT $ UNK. (See note #2)
If you have mid-controls:
2882W BOLT $ UNK (See note #4)
7710W NUT $ UNK (See note #4)
34639-93 RETAINER $ UNK (See note #4) For ’96-’00 models
34639-01 RETAINER $ UNK (See note #4) For ’01 and later
34640-93 COVER, Shift shaft $ UNK (See note #4)
3231B SETSCREW $ UNK (See note #4
NOTES:
#1; If HD Fwd controls are already on the bike, the existing part is the same P.N
.If NOT HD Fwd controls, OR is HD mid controls, this part may be needed.
#2; These parts are needed if the bike has mid controls. If HD Fwd controls are already on the bike, these parts are not needed.
#3; These are Stock FLD (Chrome) footboards and come with the PAD, I Opted for P.N. 51322-08 FOOTBOARDS (Black) from the ’12 HD custom book (I’m not real big on chrome) and my parts guy gave me a set of stock “take off” standard PAD, footrest.`
#4; These are parts listed as an option to removing the outer and inner primary cases to remove the existing shift lever shaft and, cap the holes.
Sorry, no pics yet, soon to come. Best wishes Tim
For the footboards:
4512A SCREW $ UNK
For the brake:
4997 SCREW $ 4.00
For the shifter:
NOTES:
no they aren't
the shifter pivot runs thru the bracket that holds the board.
the diameter is smaller than a touring bike so cutting and welding a touring shaft will not work for heel toe shifter. turning the shaft on a lathe will end up with an edge that will not seat correctly in the hole and will wobble.
I am buying a deluxe shift lever and shaft assembly. cutting the lever and welding on my own to make up for the length difference in the softail and the dyna.
I am seriously considering building the whole mechanism from scratch and spend all the money that I am going to save on beer .
shaft/arm 71
defender shifter 150 lists for 250!
touring shaft 17
heel shift lever 35
26 12 packs of corona and a feeling of pride in doing it my self, priceless.
I have over 150 miles of riding in checking out/buying parts that will not work. who knows how much useless information I have saturated my gray matter with. stack of old fl shifters. feeling a little obsessed with this now.
used to be "if you want it done right do it your self."
now it is more like "if you want it done at all do it yourself"
shaft/arm 71
touring shaft 17
heel shift lever 35
