2006 Dyna Recall 0126
RE: 2006 Dyna Recall 0126
There are only 3 bolts that hold the battery tray on and not a single one of them could possibly fall out. 2 are under the seat and the other is behind the battery.
I've taken my battery and tray completely out at least 4 times and not once has anything been loose. Without actually seeing the recall and the wording, this is pretty much a non issue if you ask me.
"These vehicles contain a battery caddy bolt, part number 4763, which may loosen under normal riding conditions, should this occur, the bolt can back out which allows the battery tray to shift position and then hold the battery in a position which may allow the battery terminals to contact the metal battery caddy cover and abrade through the positive terminal protective boot. If this ocurs the battery can short against the cover, causing possible sparks and possible fire, which could cause and accident leading to injury or death to the rider."
They will replace the center bvattery caddy bolt with a new bolt that has locpatch on the threads, part number 4613.
ORIGINAL: Gutman
Or...you could just put loctite on the old bolt and be done with it.
Thanks for posting the wording.
ORIGINAL: Gutman
"I feel bad for the guy that had the bolt come loose and catch fire. Bet that sucked.
I wouldn't even trust my tech. to change a bolt. The bike would probably come back leaking oil."
DougJ
And as I mentioned in my first post...which bolt is this (part number 4763?). I know the three bolts that Cobra's talking about....when I installed the harness for my heated jacket, I had to temporarily remove those bolts. Still...I don't know which bolt this write up is referring to.
Thanks.
Todd
Thanks.
Todd
ORIGINAL: veniculum
Thanks.
Todd
Thanks.
Todd
