HD wide pillion cheap fix for now
I bought one of those seats but I can't get it to mount properly. It is supposed to mount just like the stock pillion but I cant seem to push down hard enough on the front to allow the "keyhole" on the underside of the seat to slide under the shoulder of the bolt that secures the primary seat. What am I doing wrong?
nj, I am curious about something. When the stock pillion is removed, there are four foam pads stuck to the rear fender that support the pillion and protect the rear fender. They almost seem to be the reason that I can't get the new seat on but the instructions did not say to remove them. I assume that you left them on the fender....is that right?
I bought this same pillion when I bought my SB. My wife loves it. It takes less than a minute to install or remove. When you are installing it push down on the front of it and push it towards the tank too, that will get it to hook to the shoulder bolt. As far as the rubber pads go, ditch them and use spray adhesive to adhere a microfiber cloth to the bottom of the pillion. It's a better fit and it will keep your fender protected and clean. Can't go wrong for $125 plus the cost of the micro fiber cloth.
WG2011, it sounds like you removed the four foam pads that were stuck on the fender under the stock pillion. Am I right? If you did remove them, how does the fender hold up with the new seat resting directly on the fender? Seems like the fender would be scratched by the new seat without the foam pads.
Yes I did remove those rubber pads. The seat pillion will indeed scratch the fender just as the stock one does. So what I did is went to my local window tinting shop that also does 3m clear bras for the front of cars and had him make and install me a clear bra for the fender, look reall good can;t even notice it. But since I am very particular I may add some microfiber cloth on the bottom of the pass pillion as well.
As far as the 3m clear bra goes its basically a clear film that adheres to the surface you want it to. Have you ever seen the clear bras on the front of automobiles to protect the front from rock chips? Thats the stuff cut down to fit google clear bra and you will see what I am speaking of. Its clear so its tough to get a good picture of it installed all you really see is th ridge of where it starts and ends. Micorfiber is a very soft cotton (i think its cotton) material many including me use it to polish your bike with. You could take and attach it to the bottom of the pillion to prevent scratches, any other material may scratch the paint. The micofiber may still scrtach but not nearly as bad a regular terry towel or something like that.
I'm not sure what the 3M stuff is but it sounds interesting. If you have a chance someday I'd like to see a picture of your setup with the 3M product. MotoSoul11 also mentioned the microfiber cloth that you mentioned. Again I have to show my ignorance and ask "exactly what is microfiber cloth?"
bikingalot
Product Reviews
10-17-2018 07:36 PM
ThreatLevel Midnight
05-20-2012 07:45 PM
