Help me go HID.
The new LED lights are kick *** but pricey and if they go out your screwed if you don't have enough for a new one. I don't care what anybody says about life duration of the light cause brand new lights can fail from defect or just Murphy's Law when you least expect it whereas the HID bulbs if they go out can be pulled out and a regular off the shelf light put back in if your on the road or what not.
The LED bulb is one complete housing, so if on the road and it burns out, you cannot just replace with a regular bulb unless you happen to be carrying the housing that came with original set up.I am not familiar with how the HID works except that it needs a separate ballast.
Speaking of the LED one's, I have two of the 7" like Kuryakyn makes on my Jeep as auxiliary lights and they are the same way. There are 8 LED's and basically if one of them goes out you just keep running it till all of the other LED's die if you don't want to pay $300 a piece for complete units which on a bike would fit inside the 7" bucket. The plus side is the power draw is so low there is a really good chance they won't die for a long time but I wont run them in my headlights because like you said if one does fail I cant just swap in a $15 fix till I get around to buying a replacement for the LED.
NO WAY!!!! i ride with 2 guys with LED lamp, their LED can not touch the light output my HID has, not even close...
plus mine cost 50 bucks they have like 300 on their bike = I WIN
bud only way i can see you pulling this off with that lamp is run a slim line ballast and see if you can fit it in the bucket, if not you may have to cut and extand the lines on the unit to allow you to tuck the ballast under the tank or something... but there is no compare wiht HID and LED,
I run 10000 K in all my bikes the 12000 is a touch brighter but has way to much blue tint for me
Xentec is the kit i use in 4 of my 8 bikes, her car, and my truck... yes i am a huge fan! they are cheap and work great!!! been running them for over a year and only had one bulb go bad, they replaced it free
Agree, the HID will appear brighter, because it has no defined direction other than outward, unless you have a projector housing. LED be less work, and looks sweet too IMO. i was excited to see my post get reposted too! lol
https://www.hdforums.com/forum/dyna-...-on-11-wg.html
