Tall Risers
You must not have looked very hard... Google Harley 9" riser and you come up with results.
Here is the one I used:
http://www.debrix.com/Buffalo-9-1-2-...26-0585-vt.htm
Probably won't have to extend the wires either, there should be plenty shoved inside the neck of your bike. I used to have 12" risers and there was plenty of wiring, only thing I had to do was re-route my clutch cable and bend the hard brake line straight. Don't cheap out on risers, my first set were off ebay and they cracked on me, second set I had made by a local fab shop and they cracked on me. Finally I laid down the loot for a nice beefy billet set and they are solid. With risers that tall I also found that using solid bushings got rid of the excessive slop that will come with tall risers.
I am not understanding what your objection is....These DO use the HD top clamp. You dont have to use the one they supply. You can order from any of the sites straight or varying degrees of pullback.
Thats the type I got. Here is some here in different lengths that are straight http://motors.shop.ebay.com/i.html?_...506.m270.l1313
