Having some electrical issues
I am having some issues with my 2010 fxdc, I am having some issues trying to start it, maybe batery is almost dead, I recently noticed that if I have it in neutral with the jiffy stand down, engine wont start as if I was in gear.
Any ideas what could be the issue.
Make sure all battery connections are tight, try twisting the connectors to make sure they are snug. I had a problem a month back and discovered that even though I thought I had tightened them down, they weren't tight, they just had enough resistance to make them feel tight. My bike wanted to die at times and finally wouldn't start.
I gave the battery connections a twist and they easily rotated. I tightened them down a bit more and discovered that they were loose, they must have had a bit too much resistance when I first tightened them down leading me to believe that they were tight.
One other thing is to keep the battery hooked up to a Battery Tender. This will keep your battery in top shape and extend it's life. Your bike might already be equipped with a plug-in receptacle for a Battery Tender, but I had to do my own. It's plugged in whenever I park it in the garage, just like my car that doesn't see everyday use and my dirt bike that I haven't ridden for months.
