HELP....brake light issue
Old 07-31-2011, 02:18 PM
Nunezep's Avatar
Nunezep
Nunezep is offline
Default HELP....brake light issue
Noticed today that the front brake will not light up the brake lights on my 2009 streetbob. took the front brake lever off and pressed on the swich....for a while it would throw a quick small flash and then it stopped doing that..... took the harness apart to gain access to the terminals for the brake switch....threw multimeter on and set to continuity....no change.....
sounds like i have to swap out the brake switch then?? nAnybody else have this issue??
Old 08-07-2011, 08:43 PM
Nunezep's Avatar
Nunezep
Nunezep is offline
swapped in new front brake light switch....all ok now
Old 08-07-2011, 08:45 PM
DannyZ71's Avatar
DannyZ71
DannyZ71 is offline
Good to see bikes haven't changed much in the last 30 some odd years. That used to be the first thing that stopped working on every bike I owned back then.
drsnipes
12-03-2023 01:18 PM
FXDForbes
05-09-2014 08:41 AM
moblmowr
02-29-2008 08:00 PM
AZCHOKESTER
01-10-2008 10:34 PM
Skip
08-12-2006 01:48 PM
Quick Reply: HELP....brake light issue
