Switchback bags on another Dyna?
Anyone know what mounting hardware may or may not be necessary? Or if it's even possible without fabbing up some stuff?
I have the H-D leather-covered hardbags for my FXDWG, but the leather sucks and they leak in the rain. Plus they don't detach quickly. The bags on the Switchback, on the other hand, are exactly what I want.
those bags are basicly FLH bags with side flip lids...
i made a set work for my dyna using qd brackets. then welded up the removeable latch in the front and put a hinge so they swing open rather than the top removing
also cut a piece of metal for the inside to spread the weight out and rivited that to the bags side on the inside... then bolted the brackets to it... made some fender fills as well to have them look cleaner... soon ill line the inside with fur... you can do this much cheaper than i am sure they will sell those for... just an idea for ya
body work
painted
body work
painted
You are going to have to order all the parts from the Dealer and build your own kit. The key is that on the FLD there is a lower mount point that secures the bags to the rear fender. This will be the big issue for anyone that wants to add these to their bike. The upper mount is right at the same place as the normal leather bags. Also remember that on the WG, you have to relocate the turnsignal lights and plate.
Just looked at the hardstreet bags. They appear to have the same kind of seal and shape as the leather-covered hard bags already on my bike, which don't work worth a damn to keep water out.
No, I'd rather have bags that do their job. The switchback bags might be the ticket.
