Not running smooth...
I have an 07 Superglide Custom. It is stock, as far as the functional parts are concerned, including the exhaust. It has 11K miles on it and i am the 2nd owner. Bike has been running fine the last 1,000 miles since i got it. Been having issues with it dying at a stoplight / stop sign when the RPM's drop to idle when the clutch is engaged. It also feels like its hesitating at a cruising speed, almost like the fuel isn't constantly being supplied to the engine. I have replaced the spark plugs (Screaming Eagle), air filter (Stock housing and filter) and new plug wires as well (Screaming Eagle). I also have changed the oil and the primary fluid at the beginning of the season, and it may have 300 to 400 miles on it. I also run premium unleaded for my fuel. I have tried running a tank of Seafoam through the system to clean out any residual junk that the previous owner may have run through, but that has not helped either.. It seems to be worse once the bike has warmed up and has run for a bit (10 min or longer) Since its fuel injected, im not sure where to start. Obviously, i've gone past the cheap fixes and am now looking at the more expensive ones.. Anybody have any thoughts of what the issue could be?
Thanks in advance..
Thanks in advance..
Your intank fuel line could have a pin hole in it. With the fuel cap removed hit the run switch and listen while the pump primes the injectors. If you hear spaying inside the tank you'll need to replace the line on the pump. There use to be a nice write here on it, but I can find it right now.
Is the bike throwing any codes? Check the sticky on "Best of Dyna" on how to check your codes...its very simple to do and could send you in the right direction. Other than that, I have read on this site that some peole have experinced these types of issues when they ran SE plugs and/or wires.
Try switching back to the stock wires and regular HD 6R12 plugs and see if that doesnt cure your problem.
Hope you get it worked out.
TJ
TJ
Received 4,799 Likes
It's possible the idle air control (IAC) valve is gummed up in the throttle bore. Using a flashlight look in the outer edge of the throttle bore for a little hole with something that looks like a metering valve. Spray some throttle bore cleaner in it while turning the ignition on/off a few times. The oil vapors being sucked in the throttle can play havoc with that little valve.
Iac
replace it. Problem solved, good luck.
