Need help with turn signal/brake light gremlin 09 FXDB
A buddy of mine just got back from 1600 mile trip. During the ride he noticed R rear turn signal did not work, brake light was on but does not get brighter with brake use, L rear turn signal was constantly on but did not blink with turn and was melting the lense. Headlight worked fine but seemed abnormally bright, and front turn signals worked fine. Does this sound like a short somewhere?? It rained on 1 day of the ride. He replaced his bars several weeks ago and spliced and soldered wires at the time to get in and out of bars. His ride is an 09 Streetbob. Everything worked after install and before start of trip.
Thank you neighbor. That was my first thought but I was hoping it would be something simple like arcing at the TS bulb or ??? We are going to check wiring under fender and such before diving back into the bars. The bars are Todds Strip bars...1" with tight Z bends, not fun to wire!
Does he have one of the add ons that make his brake light and rear signals flash before coming on full? I mention this because I had the exact same problem a few times and it turned out to be the add on for the rear brake/signal flasher gave up. Removed it and all is well with the universe now.
I also put a piece of cardboard between the lever stop and housing before unbolting anything.
leeinmemphis
05-11-2009 06:19 PM
