Front End Clunk
My 2007 Wideglide did the same thing. Discovered that there is a shop bulletin that says replace the washer in the top of the steering head with a thinner washer and tork to 70 lbs. i thing the washer is $1.85. Completely corrected the problem. Not sure of the shop bulletin number but it was mentioned on this site several years ago.
https://www.hdforums.com/forum/gener...end-clunk.html
http://s96.photobucket.com/albums/l1...sort=ascending
I have also the "clunk" sound at the front end of my '07 SB when riding!
I tightend up my gastank, it was loose, but I also noticed a "clunk" (in I think the neck bearing) when i pull the front end, back and forward!
So I adjust it with the bearing nut in (even tightend up) every way, but it's still there.
Any further suggestions??
Thanks, Eddie
Thanks, Eddie
Received 4,845 Likes
