Carb backfiring and leaking oh my! Pic/vid
Ok guys my WG is giving me trouble. The carb has been backfiring bad as of late and it even burned a hole in the bottom of my air filter! At first I thought it was only dirty so sea foam through the tank and blasted the crap out of it with the sea foam deep creep. Runs smooth at idle but under throtle it will pop and shoot flames out of the carb. Today I notice when the throttle is open gas flows out where my finger is at the black little boot and pin needle thing. Any ideas?
Received 4,857 Likes
Ok got a new diaphragm in from HD along with a spring and o ring. Runs better but still get a carb fart flame backfire pop lol. Happens when I give just a small but of throttle. But at idle it's fine and at a lot of throttle it's fine only happens a few times with a small twist of the go stick. The plugs looked dry yet black. Put new plugs in but really did not notice any diff. What next?
