Whats an extra gallon of gas worth?
I am still considering swapping out my Low Rider tank (4.09 gallons) for a larger wide Glide tank (5.1 gallons). I added up the cost and with the tank, Speedo, bezel and bib, and I will be at 500 bucks. I used to like the narrower Low Rider tank, but with the Springer and apes I really think a larger tank might look better as well as hold more gas. Are any of you Dyna guys putting the Wide Glide tanks on for that extra cruising range, or is the stock tank big enough?
Also something to consider.... Stock Low Rider tanks go for a BUNDLE of cash on ebay (not sure why), and if I sold mine after the install I could recap quite a bit of the cost. Thoughts?
_________________________________________
What year is your bike?
Makes sense to increase the range, especially if you like the look of a fatter tank, and the cost of the conversion makes sense for you.
Better range would be a big plus in many areas where gas stations are spaced pretty far apart. I never heard a rider going through Death Valley say that he wished he had a smaller tank.
Thanks for all the responses. The bikes a '96 so I don't have the bigger tank the new Dyna's have. Not planning death valley or anything like that but more gas just seems like a convenience thing. I also have been wondering about style. I am starting to agree that the Wide Glide tank with the large single speedo might flow better with the Springer and the apes. I think its a more traditional look. I realize the Low Rider dash is basically unchanged since the '77 Shovelhead Low Rider came out, but I'm still thinking the big tank might be worth the money and effort.
Does anyone have pictures of a basic Dyna or Low Rider with the big tank and 5 inch dash mounted speedo? I realize I can just look at a Wide Glide but they are pretty different styles with all the rake and bobtail rear fender.
One of the mods I have been considering for some time is increasing my fuel capacity, but I just have not been able to justify it. I actually went from the WG 5.1 to a SG 4.7 and I do miss the extra 1/2 gallon. I have sweated it a few times. But then I do carry an MSR bottle on road trips.
All that said, it sounds like one of your primary objectives is aesthetics, which is an entirely different matter. I would say go for it if it is the look you are after.
You should be able to get more than 250 out of your tank and console, I got 500 for my WG complete.
