Do anyone know the actual size of the banjo bolt fitting (front brake line)
As I saw 10mm 12mm and 8mm
I would measure them but what's the size taken from ... the diameter ?
(Editing the title of other post didnt work)
Are you asking about the nut size, or the actual fitting itself?
Not sure, but if you have a parts manual it will list all the bolt sizes, including the banjo's.
FXDWG 2010 has p/n 41739-84A front brake master cylinder banjo bolt. This banjo bolt requires an 11mm 12-point socket and is used for 12mm brake lines.
Pre 2003 Sportster used 41747-82A 10mm BOLT, BANJO bolts on the master cylinder. Dyna/Sportster master cylinders are similar so IMO you need to try the 41747-82A for your 10mm banjo.....
