switching to 14.5 apes on my bob were to get wire ext.?
RE: switching to 14.5 apes on my bob were to get wire ext.?
would these be long enough over 48' wiring with new switches,for the price,might be easier then sodiering.would these work?+48' wiring with chrome switches
I just did mine, i went with 16 inch gimp. I found that there was alot of wire inside the frame, i didnt have to extend my wires at all. I just cut them, fed them through my bars and then reconected them and stuffed them back into the neck. It was actually pretty simple.
ORIGINAL: jackyl
If you choose to keep the stock housing and just bump up to apes, get the 8 inch extension from the link I posted so you'll have plenty of slack in case you ever decide to go higher.
Whiff
ORIGINAL: dynamac
jackyl, where did you find 14.5 inch apes. That is the size I've been looking for?
price $85.00
specs.
14.5 " Rise 36.5" Wide 8.5" Pullback 10.0" Center (inside)
Internal Wiring Accepts Hydraulic Clutch
1.25" Diameter Chrome-Tapered to the grip area.
here is the link to them 14.5 apehangers 1 1/4 thick
Just cut and extend them yourself I did on my 18's in a bout an hour all the wires are different colors so its foolproof just spend the money and buy the heat shrink connectors and take your time and do it right the first time because if you have internal woring you have to cut them anyhow why pay some company 50 bucks when you can spend less the 20 and have money for beer lol.
