Average Brake Life On Late Model Dynas
Hard to believe some of the mileages you guys have on OEM, bet you'd stop better if you replaced them. After a while you tend to get used to the way things are and ignore it. Likely don't realize how much foot your using to have to stop, until you replace the pads. $67.00 front and rear. Curious to know if these pads are like cars, in the sense they squeal when low.
i'm over 10K no brake changes yet, lots of wear left.
As stated earlier .... if you have loved ones and/or you do not have enough money to do your funeral buy life insurance asap.
In an emergency situation the back brakes will not help you stop very quickly. Example, I was in an emergency low down situation and I applied so much front and back break till my entire bike sunk down towards the pavement a lot. Very noticeable. If I did not use the front break I would have been hit.
And over-using the fronts can cause an emergency of their own.
I mainly used my fronts when i had midcontrols, until the front end dive caused a fork seal to blow.
Now with forwards i only use my front brakes to complete a stop a put my feet down, make sense?
I have used only my rear brakes in more than one emergency situation over the years.
I doubt front end dive caused your seal to blow, more likely your fork is bent and causing the seal to wear. I cant imagine trying to haul down a 600 pound bike with just the rear brakes. I used to ride sport bikes when I was a kid, and rarely touched the rears. With both my Harleys I find I need to use both front and rear, in the right amount to get the bike stoped in a hurry. No offense but you need to take an msf course or something to learn how to use your brakes because relying on the rear brake only is going eventualy get you in to trouble.
