SB with Nightster pics!!
Thanks! My buddy did a good job. That AC topped it off. It didn't look as good with the stage 1 AC. With those flat bars it's pretty comfortable too not as comfy as the Dyna though.
I took the forwards off.
Made a template out of cardboard and even mocked the sigs in it
traced it on the flat stock and cut it out with my angle grinder
Put it on, off, grind till it was flush.
Paint with some gloss rustoleum enamel I had on my shelf and that was it.
The hardest part was the sigs because of the connector, but mainly because you want to take your time with the connector then you can pull the wire straight through the controls with no splicing. Here's a thread that should help you out and hit me up if you have any questions. All in all it was an hour to hour and a half of work. Not long at all. Well worth it too!!
There are pics of my set up later in the thread below too!!
https://www.hdforums.com/forum/dyna-...rols-done.html
Oh and I ran the wires on the back side of the back bone. Someone on here went the extra distance and routed them through the little drain holes in the down tubes. If I knew those were there I would have done the same. If I ever strip my bike down for something I'll probably do that. You also need a short button head bolt for the sigs too.
