Hid
This is the kit I used
http://www.kbcarstuff.com/Motorcycle...-Kits-s/34.htm
This has both high and low beam although the lamp intensity doesn't change, it has a slider Solon that moves the beam around
Sounds weird but it does work
I have a 2 inch lift and all the electronics are mounted under the tank below where the halves come together
very clean install
By the way, they don't show a 65K dual kit but if you call them and ask, they will put one together for you
EDIT.....the bulb does not stick out the rear of the housing very far. It fits fine with one exception
I could not install the rubber boot that was over the back of the original H4 lamp
very clean install
i actually just ordered my kit and im planning on puttin it on as soon as it gets here. i have a weird light that has a grille in front of it so it blocks out alot of light therefore i had to go with something that would give me more light output. i also have the 2 inch tank lift and im planning on putting it under the tank. i will post pics as soon as i get it all togather
