Chopping up a fender, looking for opinions on the lines...
I finally got around to cutting it last night. Here is my original thread from when I bought the fender.
This is what it looked like originally:
I liked some of the suggestions in that thread so I've been meaning to do it for awhile now. It's not even bolted down all the way in this pic... I just threw it on to see if I liked it. Gotta sand it up, re-align everything and then paint.
I think it looks better with the mullet looking flat edge shaved off the top. All I did was try to cut it out to show follow the rim edge a little more on the top and back edge of the fender:
Now last night my wife suggested I cut off the point on the bottom edge of the fender. I'm torn between leaving it alone or listening to her suggestion. I drew up two ideas for lines. Wondering what your opinions are:
Idea #1:
This one is basically to hack off the point and make it a bit more curved.
Idea #2:
This one is to take a bit more off, give it more drastic curve and make it match the rear fender slightly.
Keeping in mind the whole reason for getting this fender was more protection from the water spray and debris than that useless dirt bike fender provided. More I hack off the less protection but I think it'll be a minimal difference regardless of which option I try.
So what do you guys think? Leave it alone? Make one of the suggested cuts?
Idea #1:
Idea #2:
Hey lo-rider, I think blueangel73 just about nailed it in his post in my original thread.
Ignore the red line but look at the curve/radius he has on the bottom. The black lines were Joe Knapp's suggestion and that's pretty much what I've done so far:
Yes.
Hold that line just a tiny bit longer, before blending it (much as you have shown) into the aft, bottom fender tip. Because the front fender is so much finer an element, that transition benefits from scaling down the similar feature on the back fender, keeping in mind that the outside profiles are quite drastically different (not angled back the same).
You have a good eye, and it is wise to take the time mocking things up, like this, then taping it off precisely as planned, so you can stand back and have a good look at it from many points of view.
Edit to add: Close. In this last photo, it clearly shows the impression that the inner line of the fender opening follows the wheel, and not the outside fender profile. Once that is corrected (follow outside profile, at bottom), appearance should improve.
One more thing from a very detailed perspective. I believe that the radius of the fender (especially front fenders) needs to follow the exact contour of the rim. Not saying it has to wrap the tire and follow the rim, just from a side view it needs to have the same profile/radius/contour as the rim...make sense? JMHO.
