Lighter socket position & wiring
Just curious if anyone has wired up a lighter/accessory socket to their Dyna to run GPS etc. My aim is to run my phone as it comes with GPS and I can use the mp3 player with head phones of course. I will make up a mount.
Where did you mount it and where did you wire it in to? Hopefully someone with a Dyna around the year 2000 can help out. Cheers.
I am looking at the same thing on my 2011 FXDC. Sometimes a lighter socket will vibrated around while riding and on my KLR650, the gps would vibrate on and off, so I wired it. Under the seat of my Super Glide, there is a Customer Accessory plug that is pulled out for you already fused. You can look up the part nos. for the female part in this forum and it only costs about 20 bucks. They even have an adapter for two accessories that plugs right in.
Thanks guys. Wondering if anyone has mounted one infront of the tank somewhere? Only asking as I would be plugging in a phone charger and not hard wiring a GPS unit.
HemiOrange, that looks like a great idea and thanks for the photo's, do you use the socket for anything and where do you run the lead if you want to use GPS (or similar)?
Bspike1, my bike doesn't have a battery tender unfortunately, I would need to wire something or splice into a live wire.
Under $25 at Amazon, and comes with the battery lead. After you install that, you can make up plugs for pretty much anything. You can route an extension under your tank to the front, and you can plug in a lighter socket like the one shown above.
They also make various extensions for different accessories, so you should have several choices on how you want to set it up. I have a GPS extension, with mini-USB for my Garmin GPS. Now that I have the 2" tank lift from Jackyl, it will be very easy to drill a hole in the tank lift bracket to mount a discrete lighter socket.
