Lighter socket position & wiring
I just went to the local auto parts store and picked up a plug with a rubber cap on one end and mounted it vertically on the aft end of the battery box and wired it to the battery direct with an in-line fuse. It's worked well in the NW for 7 years and the cap keeps water out. Cheap and reliable. If I ran a GPS, which I don't, it probably would be better closer to the steering head, as some have done.
Don
Don
I have the kuryakyn 12v outlet, mounted on bar top clamp, easy to access. I run power to battery, use a relay key on power.
https://www.hdforums.com/forum/dyna-...-pictures.html
