Lighter socket position & wiring
I mounted a Kuryakin Power Point on my bars for my GPS, works great.
http://www.latus-harley-davidson.com...ower-Point.htm
![](http://westbranchnewark.com/images/__gps.jpg)
I just loosened and raised the tank a little and the taped the Kuryakin connector to a 1/8" dowel and shoved it under the tank, then pulled it through and connected it to the battery terminal. Hooking it up this way the power port is hot all of the time and the GPS does not go off when you shut the ignition off.
The normal battery tender type plug will probably be your best bet. I'd run it under the tank to the front of the frame. You can just zip-tie it on the left side of the steering neck, directly under the tank mount, to the same frame mount as the tank vent hose uses.
You should be able to fish it through with a coat hanger by just removing the gas tank's rear mounting bolts, tilting the tank forward and pulling it through from front to rear.
Second, have you ridden in the rain with that receptacle pointed straight up ?
Seem to me that would drive the water down to the contact points and blow the fuse...
Easier than I thought. Bought the battery tender plug/connector which was an extension cable so it had one at either end. Cut the wires, wired up an inline fuse folder with a 10a fuse then crimped some circular elec fittings, one to the battery and one to the earth/negative. Ran the lighter socket wiring under the tank and wired up the other battery tender connector and voila, roberts ya mothers brother. 20 minute job. Just waiting on the phone cradle/mount from eBay and then I'm done.
Thanks everyone for the idea's. I feel the battery tender idea was the cheapest, easiest and best install method.
i went with the kuryakyn cig socket, it looks awesome I think. I got the 1 1/4" one and put it on the top bar of my lindby linbar right up by my frame. ran the wire under the tank and back right in front of my battery, where my battery tender plug comes out of the battery. the kuryakyn has the same plug on it as the battery tender so I can just plug the cig socket into it when I need to.
