sputhe or true track?
Old 07-01-2011 | 10:38 PM
jiminpa's Avatar
jiminpa
Default sputhe or true track?
which would you go with? its for a 2006 lowrider.
Old 07-01-2011 | 11:25 PM
SC-Longhair's Avatar
SC-Longhair
Either one will do the trick.
Old 07-02-2011 | 12:38 AM
HemiOrange's Avatar
HemiOrange
If a low mounted oil cooler is in your future, then go with the Sputhe, otherwise, either one will do. The Sputhe does have a nice added feature on the rear stabilizer that firms it up maybe better, but hard to tell if it really adds to the overall improvement.
Old 07-02-2011 | 12:43 AM
03FXD-LOW's Avatar
03FXD-LOW
Order both, then send one to me...I will take either.
Old 07-02-2011 | 09:18 AM
bikerlaw's Avatar
bikerlaw
I think they both do the exact same thing, but True Track is not only a site sponsor, they are the Dyna forum sponsor as well, so that would be my recommendation.
_________________________
Old 07-02-2011 | 03:26 PM
dlstanf2's Avatar
dlstanf2
Either one will work and you will be amazed by how much. I installed the Sputhe Positrak a couple of months ago and posted some pics and tips on the installation process. The True Track has a T-shaped front stabilizer which is made of aluminum and is thicker than the steel unit from Sputhe. Also, the Sputhe unit has a couple of locking bolts on the rear unit to secure the stabilizer to the frame.
Here's the link to the discussion. There's a link below that for the Sputhe's discussion on Dyna instability and the fix. Good Luck!
https://www.hdforums.com/forum/dyna-...a-b-tch-2.html
http://www.sputhe.com/aluminum%20swing%20arms.htm
Old 07-02-2011 | 06:26 PM
redrubicon2004's Avatar
redrubicon2004
I have a True Track and they were really friendly to me on the phone and had it to my door in under 48 hours!
Old 07-02-2011 | 08:49 PM
Spiro Drummer's Avatar
Spiro Drummer
I did True Track... Now i've got a Dyna that rides on rails...nice..
Old 07-02-2011 | 09:08 PM
missedem's Avatar
missedem
Does the true track get in the way of where a low mounted oil cooler would be? they both sound like great systems.
Old 07-02-2011 | 09:12 PM
missedem's Avatar
missedem
$369.00 Sputhe , $378.00 True Track
