Gel in the seat?
I got gel in my Danny Gray and they explained that the gel is beneath the foam so it wont matter if its firm or not in the cold. Its just a buffer for vibrations. To be honest, I can't tell its there. The seat isn't that much more comfortable than the stock seat in my opinion, it just looks cooler and cost a whole lot more.
You can cut out the foam with a utility blade and put a gel pad in yourself and save a bunch of money. The staples on the bottom of the seat material holding it to the seat pan are easily popped out and use self tapping screws to re-attach. I recently cut off some of the factory foam and made my Fat Bob seat more low profile where I sit and left the passenger area alone. Looks very good.
If you are thinking the stock seat is uncomfortable for you after only 150 miles, you may need to go to something like a mustang seat. I don't think gel will help you much if at all, and it does retain the heat if you park in the sun. You could try an air hawk cushion, mine adds another 100 miles or so comfort to my longer rides. For short rides, don't bother using it.
