FXDF Shock Length Advice Please
Just changed my 07'FXD for a FatBob,i had Hagon rear shocks on the FXD which where about 1/2" longer than the standard FXD shocks,i think the standard FXDF shocks are 12",which means the Hagons will be 1" longer,I want to fit the Hagons but i'm a bit concerened about upsetting the handling balance,can anyone offer advice please.
I don't think you'll have any issues. I put 13" Ricors on my FatBob a couple weeks ago and haven't had any issues with the handling. I'm still playing with the spring preloads, but I'm liking the improved cornering abilities. I also have the Ricor Intimidators installed in the front which helps as the stock Fat Bob front end was too soft IMO. I think you'll like it.
Im looking at the same setup for my FaTBob and was looking at the 12.5-13" shocks. I would not even consider the stock 12" as I want to get it handling as well as possible and if you raise the rear then the geometry of the motrocycle starts changing to allow quicker handling.Firming up the front end and possibly dropping it a fraction of an inch will do the same.
I'm anxious to hear EricInNCa experience after riding his for a bit........ It should be ready for a big motor and some brake work now (-:
Additionally, I have a different tail-light and plate setup which tucks up in the fender quite a bit. It makes it look like a lot of clearance. I have a spare rear fender that I am going to mod to sit lower and change the look a bit. I wanted the additional ground clearance so it's all part of my master plan...
You can definitly tell that the rear is jacked up a bit with the 13"
I beleive that the Fatbob has a shorter stock rear wheel travel than the other Dyna's at just barely over 2" ,ridiculously little. I think I have seen where the stocker is 12" and the other Dyna's have 12.5" Maybe others can confirm this.
Just have to weigh the benefits of the longer travel, better control & handling with the appearance. I personally like the Fatbob's rear fender but the bobbed fender that some are putting on them might go better with a Fatbob that has 13" shocks on it since it doesn't have the flip up at the rear... seems like it would be less noticeable
I understand about the look with it raised up. My overall plan is to mod a spare fender I have to compensate the look for the increased height. In the end, you won't notice the longer shock because the fender is gonna be mounted lower on the struts AND shortened. I wanted to get the shocks on before I went forward with this mod. Stay tuned as I'll post pics when I get this next mod completed.
